Hydraul Shift Repair Please HELP
goatfarmer
04-29-2005 18:12:20
I have a G850, (Yellow 1755), and its hydraul shift is going out. Is it true that it could cost $2000.00 to rebuild? Are there any options?
Please advise.
m kuhns
04-30-2005 07:03:51
 Re: Hydraul Shift Repair Please HELP in reply to goatfarmer, 04-29-2005 18:12:20
They are not hard to rebuild if you have any experience. Sounds like the direct drive clutch pack is shot. That is the least expensive repair. But for clutch/spacer plates alone are around $350 and the sprag clutch is another $225. New output shafts are around $1500 if needed. Seal kits for them are also pretty pricy (I think around $300). We just buy gaskets and seals needed individually. You will probably just need clutch packs and a sprag, if underdrive and overdrive work. Ball park fiqure for parts, $600.
Adam Suess
04-29-2005 20:01:40
More like $3,600 in my experience. It really depends whats all wrong and the labor rate. What does it do? Options would be a used unit.
goatfarmer
04-30-2005 05:34:14
 Re: Hydraul Shift Repair Please HELP in reply to Adam Suess, 04-29-2005 20:01:40
It operates in underdrive and overdrive, but not direct drive. That drive is just like underdrive.
Are used units available? Where? Thanks
Marc Smothers
04-30-2005 06:01:29
 Re: Hydraul Shift Repair Please HELP in reply to goatfarmer, 04-30-2005 05:34:14
First off I certainly would quit using the tractor. Most people keep using their tractor when a one drive goes out. That just componds the problem. I certainly would not take it anywhere if you have the ability to take the motor out. The 3 speed is very simple to repair. If your input and output shafts are ok, you are looking at around $500 to rebuild it. If the shafts are bad, you are looking at $1400 and $1600 respectively or at least that much!! We have fixed all are 3 speeds ourselves with many hours on them now. I have a output shaft but it is for one with a trunion mount. You can save alot of money by doing it yourself.. Marc
goatfarmer
04-30-2005 14:27:08
 Re: Hydraul Shift Repair Please HELP in reply to Marc Smothers, 04-30-2005 06:01:29
Thanks for the advice. I have stopped using it. While I have done clutch work, I haven't done hydraul drive unit. I will see when I get the motor out and the unit pulled. Thanks for the help, I certainly appreciate it.
