Exchange for Fleetline hyd pump
Tractorcedric
04-28-2005 18:21:04
I wonder if there is anyone in the business of rebuilding these pumps on an exchange. Or someone that will just rebuild mine and send it back in a timely manner? Thanks
tom upton
04-28-2005 19:49:24
 Re: Exchange for Fleetline hyd pump in reply to Tractorcedric, 04-28-2005 18:21:04
Depending on what your symptoms are you you can probably repair your self relatively easy. The worst part is getting unit off tractor as it is a bit heavy and ackward. If your pump is loseing hyd. oil but still working when you fill then it could just need lip seals in the pump? These seals are cheap and really any one with a bit of care can change. (a service manual is a good idea as well. If you dont allready have one it is a cheap investment compared to sending your pump out to get rebuilt) Hey if its not working now you are not going to make it worse, give er a try!!
