Oliver Electrical Experts
Dominic Centonz
04-24-2005 14:36:29
I have a slow cranking 1941 6-volt Oliver 70 tractor. My friend says that it can be upgraded to 8 volts by adjusting the generator(having a generator expert do this of course)and using a 12 volt battery. Anyone familiar with this or know how it is done?
Lou 51
04-25-2005 04:23:47
 Re: Oliver Electrical Experts in reply to Dominic Centonze, 04-24-2005 14:36:29
the regulator can be adjusted to put out 9 to 10 volts and a 4 cell battery installed (8 volt battery) we did this on a 400 Farmall years ago and it worked out good helped starting quite a bit and all the lights worked the bulbs did burn out faster. I don't know if you can still get the 8 volt batteries
old
04-24-2005 16:26:29
Theres only 3 reason you should have a problem with 6 volt. Weak battery, the battery cables to small/old, or the starter is getting weak. I have a 1949 77 that is 6 volts and it starts all year no matter how cold or warm it is
evielboweviel
04-24-2005 15:43:48
replace your battery cables with o or oo cables with soldered on ends. clean your ground connnection on the frame real good and leave it at 6 volts.
Ron
