Super 55 Info
South Texas Cas
04-20-2005 20:02:48
What does the specificaction number tell about this tractor and what year is it. Spec. number 15-0010 and Ser. number 13381-518. Is there a pattern to the serial numbers, like Case Flambeau tractors first two numbers minus four equals year of manufacture. THANKS Tony
J. Schwiebert
04-21-2005 03:13:37
 Re: Super 55 Info in reply to South Texas Case, 04-20-2005 20:02:48
The spec number is a system that identified how the tractor was equipped when it left the factory. The serial numbers are in concective order and include all models. This system was introduced in 1954 with the introduction of the Super series tractors.. The last 3 digits are the transmission /ring and pinon combination and are not included in the base serial number. Your tractor is an early 1955 model. Hope this helps. Questions
South Texas Case
04-21-2005 12:53:12
 Re: Super 55 Info in reply to J. Schwiebert, 04-21-2005 03:13:37
Thanks for the information. Do you know if there is a record of what the factory equipment was or is there a code to use to find out? THANKS AGAIN Tony
