Super 55 seals?
Keith Martin
04-19-2005 17:37:55
Just got in from mowing today and noticed a bad oil leak at the PTO output shaft. How difficult is it to replace this seal? Also need to replace front main seal motor. Other than removing the sheet metal and radiator, how difficult is it?
JD in da UP
04-21-2005 04:36:18
 Re: Super 55 seals? in reply to Keith Martin, 04-19-2005 17:37:55
It's not bad for either. I bought the IT manual which covers a bunch of different olivers, $20-30. It should help you identify what needs to happen. I wish I had hunted harder to find a replacement timing cover, as mine was a little worn. Soak the front seal for a couple of days, I only did it for a few hours and It didn't seal as well as it should have.
