Hydro Oil drain plug??????????????????
SJ
04-19-2005 08:46:29
The drain plug for my hydro oil on my 1550(similar to a female differential drain plug)is not a 3/8 or 1/4 or 1/2 or allen wrench, does anybody know what size it is. Theres another one about an inch to the right of it and that one is a male plug,which I could probably get out with a pipe wrench,havent tried that yet,will that one drain the oil.
Thanks
Stan
Don-Wi
04-19-2005 16:30:46
 Re: Hydro Oil drain plug?????????????????? in reply to SJ, 04-19-2005 08:46:29
It's probably a 5/16" allen then. You can get a socket set that has allen heads in them, and you could use a breaker bar if needed, if you choose to go this route.
Donovan from Wisconsin
Larry from MD
04-19-2005 08:58:06
Those plugs are hard to get out most of the time.Its easyer just to use one of the remote hose couplers.
SJ
04-19-2005 09:01:05
 Re: Hydro Oil drain plug?????????????????? in reply to Larry from MD, 04-19-2005 08:58:06
How do I know which hose to extract oil or doesnt it matter? Just disconnect one and start motor to blow out oil?
Thanks Stan
Larry from MD
04-19-2005 15:04:55
 Re: Hydro Oil drain plug?????????????????? in reply to SJ, 04-19-2005 09:01:05
You have a hydrolic lever just pull one way if the oil don't flow,push the other way.Remember to let the 3 point down fist so the oil in there comes out too.
