Oliver 1250 hydraulic problem..
jdmt49
04-17-2005 19:46:24
When I lift the 3-point it pulsates very slightly up and down in any position...it will go up and down just fine but if i want to hold it in any position it will pulsate slightly...any ideas of whats going on and how to fix...Thanks
Jerry from East Iowa
04-18-2005 06:18:38
 Re: Oliver 1250 hydraulic problem.. in reply to jdmt49, 04-17-2005 19:46:24
Hi
If I were to guess, if it is pulsing in any position it is because your 3pt cylinder is leaking by .Your valve is trying to make up for the leak and raising it just a little bit when it settles from leaking. Fairly common problem in all colors.If you have any questions please write or call. [email protected]
Thanks,
:) Jerry
Jerry's Tractor Repair
Holy Cross, Iowa
563-552-1615 or 563-590-1973
