lube pump question
j105
04-16-2005 19:21:11
The trans. lube warning light on my 105 will flash at start up for just a second. I figure thats normal until it builds pressure. After I work in the field though and the oil is warmed up the light will also flash if I thottle engine back below approximately 1800 rpm. It never flashes when the tractor is working at 2100 rpm.
Is this normal? Is the pump getting weak? Thanks for the help
cobroller
04-16-2005 22:39:30
 Re: lube pump question in reply to j105, 04-16-2005 19:21:11
I would check the pressure with a manual guage. Should be 8 to 14 psi. It's not normal for the light to come on at 1800 rpm. Could be cracked or worn lines, thin oil, faulty sending unit, or several other things besides worn pump.
j105
04-17-2005 16:57:32
 Re: lube pump question in reply to cobroller, 04-16-2005 22:39:30
thanks, I'll check with a pressure guage. the sending unit is located on trans. filter base, right?
