oliver 1750 transmission
scott rudduck
04-15-2005 08:43:04
i have recently purchased an oliver 1750 tractor
and the high low shifter is not hooked up to anything. i dont think i am missing any parts but the linkage is hanging between the bell housing and the transmission. is there a nother
transmission between the bell housing and the main transmission for high low range? also i cant get the pto to disngage. is there somthing i should look for. any help in this matter would be apprecated.
paul dyba
04-15-2005 20:42:49
 Re: oliver 1750 transmission in reply to scott rudduck, 04-15-2005 08:43:04
there should be an auxillary 3speed hydraul shift transmission between the bellhousing and main trans. the pto drive shaft goes from the flywheel through both trans, drives the hydralic pump and drives a set of reduction gears for 540 pto. the pto clutch is a wet clutch adj by a button and operated by a lever on the left side of the seat. i would suggest purchasing a I T or equivalent manual you are going to need the information
J. Schwiebert
04-16-2005 06:59:40
 Re: oliver 1750 transmission in reply to paul dyba, 04-15-2005 20:42:49
If your tractor was built before the late fall of 1967 you will have a 2 speed not a 3 speed. The 3 speed handle is next to the throttle. The 2 speed knob is on the lower part of the dash on the right side. Does your tractor have a right or left hand PTO handle. If you have a right hand handle make sure the mounting bolts are tight and the linkage is adjusted. You may also have a warped PYO clutch disk(s)
scott rudduck
04-18-2005 10:15:43
 Re: oliver 1750 transmission in reply to J. Schwiebert, 04-16-2005 06:59:40
thinks for your responce. yes the shifter is next to the throttle. i think it reades hight and lower range. i looked agin last night and it does not look like i am missing any parts and the main transmission works fine. i will check the linkage and see if that works. yes the pto handle is on the right.
