What is this noise?
Wide Open
04-14-2005 19:04:40
Finally got the 88 running for the first time tonight. Sure does run great, but when I went to take her for a spin I noticed a noise. When I back up with the tractor in both reverse 1&2 it makes a grinding sound. Almost sounds like when you grind gears tryin to put it in gear. It is not a constant grind, but it does make the sound about two times a second. Load does not change the sound, but when the engine speed is increased, the sound speeds up. Does not make noise in any forward gears. Anyone have any ideas on where it could be comin from? Yes rearend is full of oil, and the noise is not from the brakes. I was also wondering how many gal. of oil does rearend hold? Thanks, Wide Open
