S55 Front hydraulic pump
Kevin2
04-14-2005 16:51:38
Does anyone know what the front pump flows in GPM? I bought a small backhoe to play around with, and piping it into my loader hydraulics would be a cheap and easy way to go.
J. Schwiebert
04-14-2005 17:58:02
 Re: S55 Front hydraulic pump in reply to Kevin2, 04-14-2005 16:51:38
Well what kind of pump is on the front now and what speed do you want to run the enegine when you are working it?
Kevin2
04-15-2005 16:29:03
 Re: S55 Front hydraulic pump in reply to J. Schwiebert, 04-14-2005 17:58:02
Well, the loader will lift empty starting at 600 RPM, I generally work my loader at 1400-1600 because I'm driving around. So, I guess 1000-1200 RPM would be a good backhoe RPM. GPM has to peak before 1600, so I still need to know max GPM for the pump is at what RPM. Anyone know?
J. Schwiebert
04-15-2005 16:54:30
 Re: S55 Front hydraulic pump in reply to Kevin2, 04-15-2005 16:29:03
You can probably have one of say a dozen different pumps. You did not say what kind of loader you have so how are we to guess what pump you have. Is there a name, a casting number or anything that would help identify the pump? Also if a gear pump I have a formula that will let you calculate the GPM.
Kevin2
04-17-2005 12:00:19
 Re: S55 Front hydraulic pump in reply to J. Schwiebert, 04-15-2005 16:54:30
Sorry J, I am just not an expert on what can be different. I had thought that because the front drive shaft was Oliver specific, that the pump was too. Oh well, I'll just puzzle this out on my own, like I have everything else on this unit.
J. Schwiebert
04-17-2005 18:44:24
 Re: S55 Front hydraulic pump in reply to Kevin2, 04-17-2005 12:00:19
There has to be some information on the pump. Here is anoth pitch. How long does it take to extend your loader cylinders. Then if you know the bore of the cylinders we can calculate the number of cubic inch of oil displaced in a minute and determine pump output. Also if you slide your pump apart I have a formula to measure the pump and calculate the displacement of the pump. Also say you have a 20 GPm pump. Remember this is at one RPM only. Also remember that no hydraulic pump is 100% effecient. If it pumped 17 gallon it is in great shape. Questions?
