bad voltage regulator on Super 55?
Oliver T Griswo
04-14-2005 09:36:15
I shut down my Oliver Super 55 Diesel last night and had dinner. I checked back later to find a haze in the air and the generator wicked hot. I disconnected the battery and things cooled off. Is this symptomatic of a bad voltage regulator which is allowing the battery to feed back into the generator? If so, any harm in hooking the battery up to start and then disconnecting whilst running until I get the voltage regulator replaced? Thanks much...
RWT
04-14-2005 20:47:50
 Re: bad voltage regulator on Super 55? in reply to Oliver T Griswold, 04-14-2005 09:36:15
It sounds like the cutout contacts in the regulator are sticking. If you pop the cover off and clean the contacts a little it might work a while longer. This assumes you know which contacts are the cutout.
It would be best to fix it right.
However, if you run it like that, the generator will be discharging the battery any time you get below the minimum rpm it takes to get a charging current. Don't idle it.
RT
Oliver T Griswold
04-14-2005 21:11:21
 Re: bad voltage regulator on Super 55? in reply to RWT, 04-14-2005 20:47:50
Thanks for the feedback. I don't know squat about voltage regulators yet, but I'll take a look at it. In the meantime, it sounds as though I should be okay just connecting the battery to start and then disconnecting whilst running. Thanks much for the help!
RWT
04-15-2005 20:26:47
 Re: bad voltage regulator on Super 55? in reply to Oliver T Griswold, 04-14-2005 21:11:21
I hadn't really quite thought of that option but it should work if you want to do it.
RT
