Turbo swap on a 1955 w/310
Luke S
04-13-2005 08:47:09
Ok, as some of you may have read I have a turbo with a cracked exhaust housing on my 1955. It also has excessive end play. This thing is shot. It is an AiResearch T04. I have a friend who has an airesearch T04 off of an IH that looks just the same other than the exhaust compressor wheel is 1/4" larger in diameter and the exhaust housing is slightly bigger. This turbo he has is really good mechanically. He will sell it to me for next to nothing. What do you guys think the effects of the slightly bigger compressor and housing will be on my otherwise bone stock 1955. I am not looking for a puller. I am only going to bale hay with it. Will it run worse with this larger turbo? Or is it worth a try? He said try it and if it works fine, if not give it back to him. What do ya think fella's?
James2
04-14-2005 18:41:46
 Re: Turbo swap on a 1955 w/310 in reply to Luke S, 04-13-2005 08:47:09
Simple check is to put the turbo on and run with a rated load. If it smokes a lot, it is not suppling enough air and hp is suffering. The larger turbo will no doubt hurt peak torque; ie it should smoke a lot when you lug it down because it is not spinning fast enough to give the necessary boost. If rated performance is OK with only slightly gray/black, rather than "solid" black smoke let her rip. Just don't lug it to the extent that it smokes like a poorly fired steam engine.
Luke S
04-15-2005 06:46:40
 Re: Turbo swap on a 1955 w/310 in reply to James2, 04-14-2005 18:41:46
We think it'll work. It's not a whole lot bigger, and we will not be pulling this tractor very hard. Remember, the baler that it now pulls was once pulled with my 47 hp Kubota and it handled it ok. My plan is to use this turbo for now but meanwhile send the original off to be overhauled. It'll take awhile because the guy who is going to do it is a couple months behind because of the upcoming pulling season. When it comes back I will put it on after baling season is done, or if this slightly larger one works good I'll just leave it on until it gets tired and put the original back on. Does anyone know what a stock 1955 with stock turbo makes for boost p.s.i. so we can compare? Wish I'da checked stock boost before, to late now. Maybe one a you fella's know what it should'a been putting out so I have a number to compare to?
Jerry from East Iowa
04-13-2005 21:49:22
Hi,
The bigger the exhaust side, the slower the boost side turns. If you have questions please call or write. [email protected]
Thanks, :) Jerry
Jerry's Tractor Repair
Holy Cross, Iowa
563-552-1615 or 563-590-1973
Larry NE IL
04-13-2005 21:22:15
I agree with Luther. You get to try it out for free...You have nothing to lose but a few hours of your time doing the installation. Good Luck, Larry NE IL
ejr-IA.
04-13-2005 20:20:59
It is too big won't be able to spin it hard enough to make good boost.I have three of these engines stuck to the later to4's with the narrow compressor houseing kept the same size exhaust houseing and wheel but put a bigger compressor wheel and houseing on the air side.Air-research has many combinations to choose from.
luther
04-13-2005 18:42:39
If it bolts right in, I wouldn't hesitate to put it on, it won't hurt your engine, and sometime you might want to pull your tractor. Just my two cents... Good luck I had one and loved it!
Luke S
04-14-2005 06:50:43
 Re: Turbo swap on a 1955 w/310 in reply to luther, 04-13-2005 18:42:39
All this tractor does is pull a Hesston 5500 round baler. So I am not looking for a whole bunch of power. With the original turbo this thing made 108 pto HP. Even if it went down to say 90 or so, I could still get by.
