Oliver 770 Diesel
Gary
06-17-1998 05:27:44
What years were 770 D made and how much HP would one have? This one has a wide front end,13.6-38 tires/wheel weights and is in very good condition. Can someone give me an idea what tractors like this are selling for, or what you figure this one is worth. Thanks Gary
Gary
06-17-1998 07:31:51
 Re: Oliver 770 Diesel in reply to Gary, 06-17-1998 05:27:44
: What years were 770 D made and how much HP would one have? This one has a wide front end,13.6-38 tires/wheel weights and is in very good condition. Can someone give me an idea what tractors like this are selling for, or what you figure this one is worth. : Thanks Gary
PS What power plant was used and how do they hold up? TX Gary
Paul Stanley
06-17-1998 21:54:44
 Re: Re: Oliver 770 Diesel in reply to Gary, 06-17-1998 07:31:51
My Oliver books have the 770 made from 1958 to 1967. It says the 770 tested at Nebraska in 1958 as 34.92 drawbar and 48.8 belt horsepower. It used aluminum pistons in the six cylinder engine with a 1,750 max. rpm. Sorry that's all the info I can find.
Gary
06-17-1998 22:52:24
 Re: Re: Re: Oliver 770 Diesel in reply to Paul Stanley, 06-17-1998 21:54:44
: My Oliver books have the 770 made from 1958 to 1967. It says the 770 tested at Nebraska in 1958 as 34.92 drawbar and 48.8 belt horsepower. It used aluminum pistons in the six cylinder engine with a 1,750 max. rpm. Sorry that's all the info I can find.
Is there anyone out there that has one of these? Is it a keeper or should I steer clear? What is faair market value? TX Gary
Kevin Coers
06-18-1998 08:37:58
 Re: Re: Re: Re: Oliver 770 Diesel in reply to Gary, 06-17-1998 22:52:24
: Gary
I have a 770 and they seem to hold up fine. I have a hydraulic loader on it. The only problem that I seem to have is steering the darn thing. Wish someone would have put power steering on it.
: : My Oliver books have the 770 made from 1958 to 1967. It says the 770 tested at Nebraska in 1958 as 34.92 drawbar and 48.8 belt horsepower. It used aluminum pistons in the six cylinder engine with a 1,750 max. rpm. Sorry that's all the info I can find.
: Is there anyone out there that has one of these? Is it a keeper or should I steer clear? What is faair market value? TX Gary
Don
06-19-1998 11:18:21
 Re: Re: Re: Re: Re: Oliver 770 Diesel in reply to Kevin Coers, 06-18-1998 08:37:58
: I have a 770 gas tractor that has been very good and dependable.
It was used for many years as the main tractor on an Iowa farm, and since then
has been used as a chore tractor. It has a loader on it. Power steering
was available as a factory option. the early versions had the power steering
pump mounted on the back of the generator. Later versions had a seperate
power steering pump.
: : Gary
: I have a 770 and they seem to hold up fine. I have a hydraulic loader on it. The only problem that I seem to have is steering the darn thing. Wish someone would have put power steering : on it.
: : : My Oliver books have the 770 made from 1958 to 1967. It says the 770 tested at Nebraska in 1958 as 34.92 drawbar and 48.8 belt horsepower. It used aluminum pistons in the six cylinder engine with a 1,750 max. rpm. Sorry that's all the info I can find.
: : Is there anyone out there that has one of these? Is it a keeper or should I steer clear? What is faair market value? TX Gary
Denny
06-19-1998 06:39:58
I have just purchased a 77 and my dad had a 77 diesel
when I was a kid. The 77, Super 77 and the 770 are all
very, very similar. They have very smooth running engines
and are durable. I would not hesitate if you can afford
the tractor. At auctions, 770's bring from $1350 to $2000.
At a dealer lot, the asking price can be as high as $2500.
Good luck,
Gary
07-01-1998 04:05:09
 Re: Re: Re: Re: Re: Re: Oliver 770 Diesel in reply to Denny, 06-19-1998 06:39:58
: I have just purchased a 77 and my dad had a 77 diesel
: when I was a kid. The 77, Super 77 and the 770 are all
: very, very similar. They have very smooth running engines
: and are durable. I would not hesitate if you can afford
: the tractor. At auctions, 770's bring from $1350 to $2000.
: At a dealer lot, the asking price can be as high as $2500.
: Good luck,
Follow UP: This tractor sold at auction in northern lower MI for $2050. Gary
