Cockshutt 30-rear hub removal
Kurt Smit
04-10-2005 20:08:05
My axle seals leak, so I thought I would pull the wheels and hubs and replace them. The wheels came off fine, I had to heat the nut that holds the hub on and got it off, but the hub won't budge. I've heat and beat, I've heat and used a three jaw puller, powered by a 30 inch bar to the point that I'm afraid the hub is going to break. Is there something I'm missing? Does it come apart some other way? I have a service manual, but they show nothing about the rear axle? Can I remove the axle housing from the gearcase and pull the axle through, to put new seals in? Any advice/input/help would be greatly appreciated.
Thanks,
Kurt
Brent A.
04-11-2005 17:58:40
 Re: Cockshutt 30-rear hub removal in reply to Kurt Smit, 04-10-2005 20:08:05
Kurt,If you send me your phone number i will try and help you out . It would be easier than tring to explain it on here. [email protected]
krm
04-11-2005 07:20:05
Let me know how you come out on this,I need to do the same thing.
