550 with no power
hclp
04-08-2005 14:32:19
I recentley purchased a 1959 550 that was supposed to be a running tractor. After getting it home it would not start. I cleaned the carburater, gas tank, sediment bowl, replaced clogged fuel lines, new spark plugs, points and spark plug wires. Finally got it run and now it starts and idles fairly well. Tried to run it around the barnyard but it will barely pull itself on level ground. Finally got it back in the barn. with it idling I started pulling off spark plug wires one at a time. I can pull wires off cylinders 2 and 3 and it makes no difference in the way it runs. I exchanged 2and3 plugs with 1and4. The problem stays with cylinders 2an3.
Ipulled all plugs out and checked compression. All cylinders have between 120 and 130psi. What could cause this problem? Any help would be appreciated.
1755
04-11-2005 17:55:43
 Re: 550 with no power in reply to hclp, 04-08-2005 14:32:19
I put a new distributor in onse and when doing so I had marked the cap on the old one maid new wires up and put them on the disributor inthe right order but not thinking just put them on the engen in the same order right down the block 123456 but the fring order was 124563 or sometheng but it was only hiting on 2 and it sounded like 2 JDrs fiting in a mouse wheel sometheng to check it had me scraching my hed for a while
Lee W
04-08-2005 15:08:06
Did you check the cap for cracks? Make sure the firing order is right, it is 1 2 4 3.
hclp
04-08-2005 17:17:09
 Re: 550 with no power in reply to Lee W, 04-08-2005 15:08:06
Yes I did check the cap for cracks, but not with a magnifing glass. I think I will do that.
Neil Grant
04-09-2005 18:01:08
 Re: 550 with no power in reply to hclp, 04-08-2005 17:17:09
Try changing the plug wires between the cylinders which make no difference and the ones that do to determine if the wires have a break in them. I suspect that is the problem with the good compression #'s. Other possibility is the distributor wiring is not correct with the firing order. Neil
