2255 hydraulic system
Greg D
04-08-2005 04:51:32
Just finished doing some work on the 2255. Had steering box off and most lines loose. Any ideas on how to bleed (prime) the hydraulic system? I've bled the valve just above the filter and the resovoir is full. Again the system was basically dry. Also my light is staying on that shows no oil pressure in the rear end (90 weight oil). Any ideas on bleeding that system? Thanks in advance.
Greg Davis
