6 cylinder i head hercules?
Shutt30
04-03-2005 19:45:44
I have found a six cylinder Overhead valve engine and I am wondering how to tell what it is. The tag is gone. It came off of a rock crusher and the owner said it was supposed to be a 150 crankshaft hp motor. It is green in color and has a electric fuel pump on the left hand side. I belive (not sure saw it in the dark) the exhaust and intake were on the right hand side. I dont know if it is a 3400 or 4800. Any help would be greatly appreciated. Thanks
Troy
J. Schwiebert
04-03-2005 20:41:33
 Re: 6 cylinder i head hercules? in reply to Shutt30, 04-03-2005 19:45:44
A 4800 will have two cylinder heads. A 3400 will have one. A 3400 will have the same external physical dimensions as a 298 and the valve cover will taper in on both side on each end for a little bit. I don't know if the 3400 blocks are symetrical like a GO where the distribtor can be on the right or left side. Get some casting numbers.
