oliver super 99GM
steve.friedlander
04-02-2005 17:52:53
we recently bought an oliver super 99GM tractor.we had the engine professionally rebuilt.head was redone,engine was given new sleeves,pistons,rings bearings and seals.the blower was completely rebuilt with new bearings and seals.when the engine warms up it runs great with no slobber.when you first crank the engine it runs rough,blows blue-white smoke for approx 5 minutes and will continuosly sprinkle you with oil slobber for about 20 to 30 minutes.the company whom built the engine is STEWART-STEPHENSON one of the premier 2 cycle detroit rebuilders in the country.they said you need to work the crap out of the engine to set the rings and it may take up to 200 hrs before the seat.i want to know if anyone else has had this experience with detroit desiels and is this common with one that is newly rebuilt.this is our first experience with this type of diesel engine.
tom upton
04-04-2005 19:14:04
 Re: oliver super 99GM in reply to steve.friedlander, 04-02-2005 17:52:53
I have no exp. with 71 but have 53 series that did the same thing when it had broken rings. It is real easy to break a ring when installing pistons into sleeves. Even an expert can can get a expander overlapped if he is not real carefull.You can check for broken compression rings by removeing air box covers but I am not sure how you check the oil rings. Maybe some of the guys more experienced with the 71 series might shed some light here?
Lee W
04-04-2005 07:54:25
Are you using the HV style injectors or N series injectors? The HV's are low pressure the N series are high pressure. The one's I have built I have used the 18-1 compression pistons with N series injectors.
steve friedlander
04-04-2005 18:48:13
 Re: oliver super 99GM in reply to Lee W, 04-04-2005 07:54:25
LEE,we are using the stock 17 to 1 comp ratio pistons with HV7 injectors.
Lee W
04-05-2005 08:56:21
 Re: oliver super 99GM in reply to steve friedlander, 04-04-2005 18:48:13
Steve the N series injectors would be a big improvement, they can be used on the two valve head if that is what you are using. You might have to modify the rack tube or get a later tube, three of the inj lines would have to be changed as they are differnt length's.
scottf
04-05-2005 18:22:24
 Re: oliver super 99GM in reply to Lee W, 04-05-2005 08:56:21
Lee
You can order "standard body" N-series injectors for the 2 valve heads. That way you don't have to get different jumper tubes or modify the rack. Simple. Same price. Only use "offset" injectors if you have a 4 valve head.
scottf
04-03-2005 21:29:40
I've built a number of those engines for tractor pulling. None of the ones I ever build run rough or blow smoke after I rebuild them but I do get some slob sometimes. Not always. If they do slobber it only takes about an hour under a heavy load to put an end to the slobbering. I would say you have a problem. But you don't say what compression pistons you used, what the temperature is when you started it, or what size your injectors are. If your builder used 16 to 1 pistons, it's only 30 degrees out, or you installed injectors that are to big you may have the problems you described.
Would you mind telling me what it cost to have a "premier" engine builder do a 3-71? Thanks.
steve friedlander
04-04-2005 18:44:13
 Re: oliver super 99GM in reply to scottf, 04-03-2005 21:29:40
scott,we installed the stock 17 to 1 compression ratio pistons and HV7 injectors.the temp outside is around 70 degrees.what type of heavy load are you talking about?
scottf
04-05-2005 18:15:59
 Re: oliver super 99GM in reply to steve friedlander, 04-04-2005 18:44:13
The original pistons in the Super 99 were 16 to 1. The N-series 71 pistons are 18.4 to 1. I can't even find a 17 to 1 piston available and I check two sources so I am not sure what pistons you have. You may want to check again. I can tell you how to tell the difference if you like. The high compression pistons and N-series injectors make all the difference in the world. Night and day difference. They start and run so much better. Not to mention make a good deal more power. I rebuild perfectly good running engines with 16 to 1 compression ratio pistons. I can not imagine anybody using 16 to 1 pistons when rebuilding an engine today so hopefully you have the N-series pistons and liners. It's not that hard or expensive to replace your HV injectors with N-series injectors. N-series injectors deliver the fuel at higher pressure and have a better spray pattern. If you have low compression pistons and HV injectors the problems you described may be normal. But I would ask a premier engine builder why they used low compression pistons.
Anything you can do to put your engine at an 80% or more load factor for an hour or so should seat everything. Your best bet would be to put it on a dyno. But most Super 99 don't have a PTO. You could pull a heavy implement like a plow. I have even pulled a dump truck around on the road for a while. The dump truck works pretty good because the truck driver can really make the engine work by riding the brakes. Make sure the gauges work. If the temperature does not come up you are not working it.
Larry from MD
04-03-2005 10:24:29
A friend had a recently rebuilt s99 do the same thing.He did work it hard and it still did it.I went to look at it and found it was running on 2 cylinders.I removed the 3rd injector and the tip had been broken off.You can remove the valve cover and hold down one injector plunger at a time while the engine is running to see which one affects the running of the engine the least and that will be the bad one.
RAB
04-03-2005 00:32:22
It can be a problem with any lightly loaded diesel engine, whether new or older. Presumably the rods were checked for straightness at overhaul, and injection equipment is working as spec? A bent rod may never allow rings to seat and a poor spray pattern from the injectors may cause incomplete combustion. The advice of your rebuilder should be followed. Regards, RAB
