Oliver Tractor Model 1850
Wes Dixon
04-01-2005 06:33:07
This tractor sticks in gear when under pressure. Can't back up after the loader is loaded. Have to jack up back wheel to take pressure off to get it out of gear.
Kelly MT
04-02-2005 06:50:10
 Re: Oliver Tractor Model 1850 in reply to Wes Dixon, 04-01-2005 06:33:07
My 1850 did the same thing last winter. It was the tube the throwout bearing rides on. It was wore clear through and gone. The clutch was wore pretty good to. I replaced everything while I was in there. Surface that flywheel to. It"s a big job but not to bad. The parts arn"t that bad either. Good luck, PK.
J. Schwiebert
04-01-2005 07:46:44
If you have a hydrapower or an over under which range are you running in?
CEB
04-01-2005 06:53:17
Sounds like it might be time for a new clutch, you could try adjusting it according to your operators manual first, but it probably needs a new clutch.
