larrry h I have a 1850 question
Johnnie T
03-31-2005 19:50:30
I seen where U have 4 or so 1850 gas. I just overhauled mine and the marvel schibel carb. was in bad shape could not adjust the load mixture bearing on throttle shaft bad, talked to Tom at O Brien Eq. and decided to get new zenith carb. Pulling a 16" disc in sandy loam 3 dir. and using app. 5 gallons per hour. Was wondering what your 1850 gasser where doing on gallons per hour and if U had any on a zenith carb. Thanks in advance.
luther
04-02-2005 18:57:33
 Re: larrry h I have a 1850 question in reply to Johnnie T, 03-31-2005 19:50:30
That's not bad, RUN it!
J. Schwiebert
04-01-2005 07:45:23
Just reading your post on the load adjustment. I always though they were a very good carburetor, but the average person did not understand them. Did you check the diaphram and did you check the condition of the power jet with the carburetor off and a vacuum gauge?
