Oliver 88 Questions
Wide Open
03-29-2005 18:37:21
Hey guys, I just picked up my 88 and have a few questions for you. First of all what should the valve clearences be set to? Second, what plugs should I use? Also, the tractor has a tank heater on it and I want to remove it. Can I just remove the hoses from the side of the block and put plugs in them? The hose comes out on the lower part of the upper radiator elbow, and enters the block about 6 inches from the back of the block. Is it OK to just plug it off, or is it a thermostat by-pass. One other thing, will 15.5 X 38 tires fit on the 13 inch rims? Thanks for the help-Wide Open
ejr-IA.
03-29-2005 19:31:44
 Re: Oliver 88 Questions in reply to Wide Open, 03-29-2005 18:37:21
Valve setting are gas inlet .010 exh .016 if diesel its .010 and .020. Just put pipe plugs in the heater out lets.Calls for d21 champions I use autolite 386 .025 plug gap.Tires will fit but be a little more rounded on the tread.
