Oliver tractor info
Dustin Rhynerso
03-28-2005 18:32:40
I have an older Oliver Tractor , ser. # 43058-702 , row crop , wide front end. Trying to identify year and model. Any help appreciated.
J. Schwiebert
03-30-2005 15:40:06
 Re: Oliver tractor info in reply to Dustin Rhynerson, 03-28-2005 18:32:40
Define "Other information"
J.Schwiebert
03-28-2005 19:17:34
It is a Super 77. Year, going by memory but it is a late 1956 or early 1957. The true 1957 the battery compartment cover is attached to the hood with four screws and it has 12 volt (gas) electrical system and key start. If it does not have these items and the hood etc. are original it is a very late 1956 model.
Dustin Rhynerson
03-28-2005 19:30:19
 Re: Oliver tractor info in reply to J.Schwiebert, 03-28-2005 19:17:34
Hello and Thanks. A few more things to narrow it down , perhaps. Has no key , push button starter switch , and as you sit in the seat, on your left hand side axel housing , it says Oliver , and the right side says row crop. 6 cyl. gas , with power steering , under the dash , by your left knee , is a tag that says , specification # 17-1761. Can you tell me any more ??? Thanks
J. Schwiebert
03-29-2005 03:56:04
 Re: Oliver tractor info in reply to Dustin Rhynerson, 03-28-2005 19:30:19
It is a 1956 model Super 77. If it has the Oliver power steering and not an add-on unit it is a little more unusual. The spec number verifys that it is indeed a Super 77. I do not have the code to break down the last couple of digits which even deal with optional wheels & tires, etc.
Dustin Rhynerson
03-29-2005 22:13:17
 Re: Oliver tractor info in reply to J. Schwiebert, 03-29-2005 03:56:04
Do you know where I might look to find some more info on this tractor?
