77D numbers
Jim Meade
03-28-2005 11:14:05
I bought a 77D wide front and think the engine has been worked on. I'd appreciate any help on these numbers:
SN: DS1346577C 77D I think this is a 1951
On block:
185220-F
104-306A
7302 - pointer on clock is at 6
Has tin valve cover
Intake manifold
A214M
241681
Exhaust Manifold
13168
A524M
Pump, Bosch American
RSB6A 70Y2920A1
1818246
Cust # 60446
I can't get at the head numbers. My wonder is whether this is a 770 block? I suspect the manifolds are original, maybe the valve cover, as well.
This tractor has the industrial style levers on the hydraulic pump
J. Schwiebert
03-28-2005 17:52:47
 Re: 77D numbers in reply to Jim Meade, 03-28-2005 11:14:05
Yes the block is a 770. I can remember one of the first service bulletins I read back in early 1961 telling that improvements had been made in the block and the casting and part numbers changed. Your block is one of those so it was made after that time, The original pump would probably have been a PSB Z model instead of a Y model. Your tractor should also have the flat fuel lines instead of the vertical stacked lines like the 52 and later tractors had.The front cover was also different. What in your mind are "industrial hydrauluic handles"? Questions
Jim Meade
03-28-2005 18:25:19
 Re: 77D numbers in reply to J. Schwiebert, 03-28-2005 17:52:47
I got the head number and it is for a 77, so my guess is this tractor had an engine problem and someone used a 770 short block and put all the 77 accessories and head back on it.
The hydraulic levers are two rods that come up under the steering wheel and turn to the left as two flattened handles.
J.Schwiebert
03-28-2005 19:20:22
 Re: 77D numbers in reply to Jim Meade, 03-28-2005 18:25:19
It just might be a 770 block. The 770 crank and rods would make it a little stronger. Those handles are a little unusual. I have only seen one set. There should be no electrical stuff for a hydralectric on that unit.
Jim Meade
03-28-2005 19:25:29
 Re: 77D numbers in reply to J.Schwiebert, 03-28-2005 19:20:22
You're right that there are no electrical components in the hydralectric.
I'm going to part the tractor out, I think. Has a wide front. Runs OK. Sheet metal is not too bad.
