2255 Hydraulic system flush
MikeOwi
03-27-2005 08:26:09
Time for me to start thinking about farm equipment again. Last year I started to replace the hydraulic pump on one of my 2255's. Found the pump had gotten so hot that it not only ground the pump up pretty bad, but also wrecked the small cooling pump behind it. I assume I also have a deposit of materials lying on the bottom of the oil pan. Any way to flush this out without removing the cab and upper control unit for the 3 point hitch? I already did get an AGCO filter instead of a secondary market filter.
ScooterBuck
03-27-2005 16:41:12
 Keep changing filters in reply to MikeOwi, 03-27-2005 08:26:09
You will need to change and flush the oil along with the filter a couple of times to try and get it flushed out. Short of buying a flushing system and removing all the hydraulic lines and flushing them you will probably always have some contaminants in your system. The more often you change your hydraulic oil and filter the better off you will be.
J. Schwiebert
03-27-2005 14:20:13
 Re: 2255 Hydraulic system flush in reply to MikeOwi, 03-27-2005 08:26:09
Get more than one filter, you will need it. You did not say what kind of cab you had, anyhow if you can get the seat off and the top hydraulic cover I would be getting in there with a magnet. Right now I am trying to remember if the ones with the charge pump are plumbed with the same fitting comming out of the reservoir as the earlier ones. If so, can you can get that elbow off so you can work through that opening with a magnet and flush it good. Remember th rule of thumb for piston pumps is no filter courser than 10 micron and the eyes can only see40 micron so you need to get contamination out that is four times smaller than you can see. Questions?
