Cockshutt 1850 3 point hitch hyd question?
jdomot
03-26-2005 17:22:21
How do you operate 3 point hitch and single acting cylinder at same time. I read in the manual you can not do this and I have tried with no good results. Also when hooking up a loader do you connect up to the Rod port and base port?
Thanks in advance for you advice and help
Larry from MD
03-27-2005 11:04:22
 Re: Cockshutt 1850 3 point hitch hyd question? in reply to jdomot, 03-26-2005 17:22:21
As long as the single acting cylinder has plenty of weight on it and the 3 point is light you can use them together.You can get lots of feed back problems when weight is added to the 3 point.
J. Schwiebert
03-26-2005 17:58:50
The answer to the first question is true. One thing you might want to do is scroll down toward the bottom of this page to the question on the 1800 C series with power-beyond. The addition of power beyond and a seperate valve for the loader would solve that problem. Also if you add a valve such as a Gresen SPK you will have a "float position on your loader cylinders. This will allow you to let the loader follow the contour of the land if that is important plus it allows you to have power up and power down. Questions?
jdomot
03-27-2005 06:09:10
 Re: Cockshutt 1850 3 point hitch hyd question? in reply to J. Schwiebert, 03-26-2005 17:58:50
Thanks J. Schwiebert on the information. I now understand how to do this procedure.
jdomot.
