Super 55 year model
Lawrence Davis
03-22-2005 18:02:29
I recently purchased a Super 55 and need to find out what year the tractor was built.The only readable numbers on the serial plate are ??15-0005.Thanks to anyone who can help.
J. Schwiebert
03-22-2005 19:09:00
 Re: Super 55 year model in reply to Lawrence Davis, 03-22-2005 18:02:29
I don't get the 2 question marks in front of the 15. You have the Spec number. Can you make out any numbers on the second line. it is an earlier Super 55.
Lawrence Davis
03-23-2005 02:51:07
 Re: Super 55 year model in reply to J. Schwiebert, 03-22-2005 19:09:00
The serial tag is in poor condition.The numbers have been rubbed off on the second line.I think that a couple of more numbers should be where the question marks were.Are there any other things to look for that might tell me what year this tractor is? It is a gas tractor.
super55ollie
03-23-2005 05:14:24
 Re: Super 55 year model in reply to Lawrence Davis, 03-23-2005 02:51:07
Before you give up on the tag try a magic marker. Try going lightly over it. If this doesn't bring anything out go over it again very heavily and wipe it off with some parts cleaner on a rag. It should bring up something.
J. Schwiebert
03-23-2005 03:50:48
On the right rear flange of the enegine is the engine serial number. Check it. If you think the PTO handle is the original one how long is it?mThere are also other changes. One being how long is thedipstick for the hydraulic fluid and where is it located? Start there
Lawrence Davis
03-24-2005 02:45:17
 Re: Super 55 year model in reply to J. Schwiebert, 03-23-2005 03:50:48
I will look the tractor over good and take the measurements and post back later.Thanks.
Lawrence Davis
03-24-2005 16:33:28
 Re: Super 55 year model in reply to Lawrence Davis, 03-24-2005 02:45:17
Pto lever is 28 1/2 inches from center of shaft to tip of release.Hydraulic dipstick is 2 1/4 inches long.Numbers i can see on second line of serial tag are;35-408-618.
J. Schwiebert
03-24-2005 18:15:54
 Re: Super 55 year model in reply to Lawrence Davis, 03-24-2005 16:33:28
Tractor is a 1956 model. Last 3 numbers are 518 not 618. Those 3 numbers are your transmission code. There is no 618 for a Super 55. Questions.
Lawrence Davis
03-25-2005 02:47:06
 Re: Super 55 year model in reply to J. Schwiebert, 03-24-2005 18:15:54
Thanks a lot John.Yes you are correct about the 518.I copied it wrong.I will have more questions for you later about this tractor.
