Massey 1100 crank
JerryB
03-22-2005 10:36:35
I have stumbled across (literaly) a good crank for a MF 1100 gas. Will this fit in a super 88 block or only in the 320 ????
I know it will have to be line bored for different bearings, ect but has any one ever tried this?
A.P.
03-22-2005 12:13:45
 Re: Massey 1100 crank in reply to JerryB, 03-22-2005 10:36:35
Align boring the block is a good idea if you are building a high performance engine. The crank will drop in except, if memory serves coorectly, the nose is bigger. The mains are the same diameter. The rod journals shjould be 2.625 on the 1100 crank. They can be offset ground for additional stoke. The 1100 crank pressure libes the rod journal. The higher volume oil pump from a seven main bearing engine or even the pump from the 1100 engine would be a good idea.
