Operating an OC-4
Oliver-Newbie
03-22-2005 10:20:39
I bought a reprinted operators manual and found the following on page 1-3, item #10.
Talking about the transmission it says to never shift while the clutch is enaged (obvious), and then �never shift while the tractor is in motion�
Is that true? You don�t shift up through the gears like a car? I've only used 1st gear in and out of the barn, now I'd like to go 1 mi out the field road and seems like a higher gear would be handy if I don't want to take all day :-)
old
03-22-2005 13:14:01
 Re: Operating an OC-4 in reply to Oliver-Newbie, 03-22-2005 10:20:39
Yep you should not shift gears on the move. Thats true on most tractors. Just put it in high gear and ease the clutch out, and if the engine is good it should slowly take right off.
