Motors for 1850 gas
Cliff
03-20-2005 17:39:08
Hi, I have a question about my 1850 gas. The engine has been getting weak for awhile and has gotten a knock to it. I was wondering if an engine out of a combine or another unit would work? I have seen V-8 gas engines installed in older olivers, can this be done in my 1850 or is it too much of a project? I don't use the tractor much so I thought it might be a fun project. Any suggestions? Thanks!! Cliff
Johnnie T
03-22-2005 18:49:08
 Re: Motors for 1850 gas in reply to Cliff, 03-20-2005 17:39:08
I jusy rebuilt my 1850 gasser, new clutch, carb elect ign,and hyd pump still trying to get new zenith set right but run and pulls great.
J. Schwiebert
03-22-2005 19:10:38
 Re: Motors for 1850 gas in reply to Johnnie T , 03-22-2005 18:49:08
WQhat happened to the old Marvel carburetor?
Johnnie T
03-23-2005 18:50:14
 Re: Motors for 1850 gas in reply to J. Schwiebert, 03-22-2005 19:10:38
bearings where bad and made groves in the throtle shaft decided to get new one and Tom sold me a zenith for a 1855 still trying to get load jet on its most lean setting
j meyer
03-20-2005 21:39:04
the most reasonable thing to do if you dont want the gas engine is to put in the 354 Perkins for the 1850 Diesel, but that will require switching the frames. Also, a good engine is the 5.9 Cummins, and that will make it a heck of a tractor. Yes, you can fart around trying to get other engines in there, but I guess I wouldnt bother. The options I listed above are ones I would do myself. Up to you, i guess.
Clff
03-22-2005 05:03:36
 Re: Motors for 1850 gas in reply to j meyer, 03-20-2005 21:39:04
Thank you, We like the gas for winter starting but it looks like the diesel might be the only option.
