Oliver plow parts
Will Brooks
03-19-2005 12:13:09
Does anyone have a good source for parts for my oliver 3 bottom plow. I think it is a 3241. I am located in Vermont
Thanks
Will
larry h
03-20-2005 06:07:47
 Re: Oliver plow parts in reply to Will Brooks, 03-19-2005 12:13:09
we sell oliver plow parts new and used
Will Brooks
03-20-2005 07:19:01
 Re: Oliver plow parts in reply to larry h , 03-20-2005 06:07:47
Larry,
How do I contact you?
Will
Don-Wi
03-19-2005 15:07:16
Wear parts or what? Most of those should be the same as the newer models. Shoup has them, or if you have a good farm suply store that stocks tilage parts, they should have atleast the commonly worn parts, and be able to order moldboards or whatever else you need for the bottoms. Some DMI plows used Oliver parts, and Oliver also made plows for Case and Ford.
Hope this helps.
Donovan from Wisconsin
Will Brooks
03-20-2005 04:29:33
 Re: Oliver plow parts in reply to Don-Wi, 03-19-2005 15:07:16
Donovan,
Thanks for the reply. I have the shoups catalog for wear parts. I have something busted in the trip mechanism. I have not gotten the torches out to free up the bolts to take it apart yet so I do not know what is broken. How would I cross reference the plow to another brand?
Will
J. Schwiebert
03-20-2005 08:41:05
 Re: Oliver plow parts in reply to Will Brooks, 03-20-2005 04:29:33
Before you get to far into this cross over especially for Ford plows while Oliver did make them, not all things interchange. The smart thing would be to get a manual for your plow from the museum and get a parts book for an Oliver plow such as a semi-mounted 565 and a plow bottom catalog. Here if you needed parts for a fully mounted like your 3241 people will ask what that is while a semi-mounted setting around to be parted out is much more common. Questions?
Will Brooks
03-20-2005 09:13:34
 Re: Oliver plow parts in reply to J. Schwiebert, 03-20-2005 08:41:05
Can you give me specific information on how to contact the museum you refer to for manuals?
J. Schwiebert
03-20-2005 10:58:35
 Re: Oliver plow parts in reply to Will Brooks, 03-20-2005 09:13:34
Call 641 228 1099 they are on Central standard time or e-mail [email protected]
