Super 55 Hyd
Edward Schulte
03-19-2005 07:32:22
My 3-pt settles down and then raises up ,it keeps doing this with weight on drawbar.What is wrong, and how much expence? Thanks for any help.
J. Schwiebert
03-19-2005 17:42:27
 Re: Super 55 Hyd in reply to Edward Schulte, 03-19-2005 07:32:22
Your problem is an internal leak. Now the question becomes what is the serial number of your tractor or if no serial number is your hydraulic filter on the gearshift side of the unit or in the front of the unit? Also how much weight is on the drawbar and how often does it settle?
Ed Schulte
03-20-2005 17:55:07
 Re: Super 55 Hyd in reply to J. Schwiebert, 03-19-2005 17:42:27
In reply to Mr. Schwiebert the s.n. on super 55 is 12-574-518, the filter is on left side of hyd unit. I have a 400 pound blade on 3 pt and it settles several times a minute.Thanks for your help
Ed Schulte
03-21-2005 04:57:25
 Re: Super 55 Hyd in reply to Ed Schulte, 03-20-2005 17:55:07
My unit does not have a stand pipe, we use red dextron hyd oil.The little lever is all way down, have tried diff positions and still settles when grading my lane.
J. Schwiebert
03-21-2005 09:31:43
 Re: Super 55 Hyd in reply to Ed Schulte, 03-21-2005 04:57:25
Well you have an internal leak. Where are you located? Do you have any ISO or SUS ratings numbers for your fluid? A thicker fluid has a good chance of helping solve your problems.
Ed Schulte
03-21-2005 10:39:06
 Re: Super 55 Hyd in reply to J. Schwiebert, 03-21-2005 09:31:43
Thanks for help, we are in East Iowa.
J. Schwiebert
03-21-2005 15:36:08
 Re: Super 55 Hyd in reply to Ed Schulte, 03-21-2005 10:39:06
If you have a worn or broken piston seal that will not solve your problem. If you have spool leakage it will help. Questions?
J. Schwiebert
03-20-2005 19:33:44
O. K. right now I wonder if you have the stand pipe for the increased oil level. The next thing, what are you using for hydraulic oil? Now look on the right side of the unit kind of under the seat and find a little lever that can be in position or draft control. In which position is yours now?
ShepFL
03-19-2005 12:31:24
My 550 does the same thing and I have seen no harm. Not sure of the cause but from what I have learned here it should not be cause for alarm.
Once an implement is in place this action ceases.
Just my experience,
ShepFL
