Oliver 60 is heating.
Rod Hergott
08-20-1999 14:56:37
My 60 is heating. I haven't taken out the thermostat yet but I suspect that will be the culprit. If I simply remove the thermostat will I damage the tractor? I don't use it in winter time and I don't use it on heavy loads.
Bob M
08-23-1999 09:30:56
 Re: Oliver 60 is heating. in reply to Rod Hergott, 08-20-1999 14:56:37
I don't recommend running your tractor without a t'stat. Engine will be slow to warm up, and unless you work it hard in hot weather, it will always run cold. This will cause a quick buildup of raw gas, condensation, acid, etc in the oil. That in turn will cause the motor to wear out way before it's time.
When you change the t'stat, good idea to flush the radiator at the same time - it's highly probable that's where your problem is.
Don
08-25-1999 10:58:40
 Re: Re: Oliver 60 is heating. in reply to Bob M, 08-23-1999 09:30:56
There is another problem at least on some engines. I do not know specifically about the Oliver 60. Instead of not heating up, the engine may actually overheat. The reason for the over heating is that without the thermostat the water flows too fast through the radiator. If the water flows too fast it does not spend enough time in the radiator to cool it. You can solve this problem and still not buy a new thermostat if you just break the thermostat so that it stays open all the time and then put it back in. This way you will still have the restriction of the thermostat but it will not close. Now you may have the other problem of the engine not getting warm enough.
Don
