Oliver Super 44 4 cyl gas - PTO clutch
Steve Peoples
03-16-2005 07:18:23
I believe I have burnt the PTO clutch in my Oliver Super 55 (4 cyl gas) tractor. I was using a sickle-bar mower in one of my ditches cutting cattails when the mower blade stopped moving. After removing the mower, I noticed that the PTO still turned when the tracor was running, but when put under a load, it doesn't turn. I'd appreciate any suggestions on how to replace the PTO clutch. I understand that the tractor must be split to accomplish this, but since I've never done this type of work on a tractor before, I'm looking for potential pitfalls from someone who may have done this before. I have a pretty good repair manual and have replaced clutchs in trucks before. Are there other things that I should do since the tractor is split? Other seals gaskets that make sence to replace since the tractor is alreasdy split? I'm trying to save $ by doing it myself and want to get the most bang for my buck.
J. Schwiebert
03-16-2005 16:27:05
 Re: Oliver Super 44 4 cyl gas - PTO clutch in reply to Steve Peoples, 03-16-2005 07:18:23
Have you taken the inspection plate off and looked in there? Have you tried to adjust the PTO clutch? How much effort does it take to snapp the handle overcenter?
Steve Peoples
03-17-2005 06:16:47
 Re: Oliver Super 55 4 cyl gas - PTO clutch in reply to J. Schwiebert, 03-16-2005 16:27:05
I have not taken off the inspection plate or tried to adjust the PTO clutch. It takes little to no effort to snap the handle over-center, and that is why I believe that I burth the clutch out and will need to replace it. This weekend I was planning to tear into it by draining the fluids, splitting the tractor, and taking a look at what's inside. I have a repair manual, but not having done this before to a tractor, I'm a little intimidated.
RickB
03-17-2005 14:53:54
 Re: Oliver Super 55 4 cyl gas - PTO clutch in reply to Steve Peoples, 03-17-2005 06:16:47
Be a lot simpler to try to adjust it up before gutting the whole thing. It could be toast, but it could also be out of adjustment.
Steve Peoples
03-16-2005 13:51:13
 Re: Oliver Super 55 4 cyl gas - PTO clutch in reply to Steve Peoples, 03-16-2005 07:18:23
Tractor should be Super 55 not Super 44
