question about which engine I have 1800 B
Jeff Oliver
03-15-2005 20:14:05
I have been reading though the archieves trying to find info on my tractor and have found something I think is conflicting although i may just be me. My I&T manual lists my tractor as having a 310 motor and the 1850 having a 354. from what I have been reading the 1755,1855 and such have the 310. Mine runs good and seems to be strong so I am confused.
Does the 1800B diesel have a 310 W engine or a perkins or what?
A.P.
03-16-2005 02:14:42
 Re: question about which engine I have 1800 B in reply to Jeff Oliver, 03-15-2005 20:14:05
Yor 1800B diesel should have a 310 with the indirect injection (energy cell/pre-combustion chamber) head. The same was true for the 1800C series diesels. The latere tractors used a 310 direct injection engine with the exception of the 1850 diesel which used a 354 Perkins.
Jeff Oliver
03-16-2005 03:21:19
 Re: question about which engine I have 1800 B in reply to A.P., 03-16-2005 02:14:42
Thanks I appreciate that! Now is the one I have the bad one or a decent one or are they the same engine just different injection systems? Hehe not that it really matters I guess as it's not like I am going to pull it out and swap it for the heck of it you know? :)
Don-Wi
03-16-2005 20:33:12
 Re: question about which engine I have 1800 B in reply to Jeff Oliver, 03-16-2005 03:21:19
They really start having troubles when you put on a turbo w/out an oil cooler, like the early 1855's. Your 1800 should be fine, as it's not turboed and it's not cranking out the hp like those engines in the 1855's & 1955's.
Donova from Wisconsin
