J Schwiebert/770
B Griffin
03-15-2005 04:55:18
You previously helped me with my 770. I just discovered I have an 11" clutch not a 10". I understand that the 11" is for an 880. Now I've become uncertain about this tractor. The serial # is: 65749-735. I was wondering about the engine. The numbers stamped on the block are:
185220E
1MB-100-B
4148
Can you tell me if this is the original engine? & any other particulars that I may need as I go through this. Thanks in advance for your help.
J. Schwiebert
03-15-2005 12:41:49
 Re: J Schwiebert/770 in reply to B Griffin, 03-15-2005 04:55:18
Well I am glad I could be of help. Now the 11 inch clutch was an option. I do not remember putting one in a 770 but we had put some 232 Super 77 Diesel engines together and we probably put the 11 inch clutch in 50% of them as the 10 inch would not give the life some expected. All your numbers check out. You have a 1958 tractor in case you did not know.
