550 bottom end
old dude
03-14-2005 05:36:22
Got hold of a 1958 550 gasser last fall strong runnig little brute how ever it had a soft clutch and a slight knock at low rpm. Figured the thurst on the mains were shot. Split her yesterday. Crank looks fine bearings were worn. center main had lost rear thrust , clutch was heading south fast. I can locate all the parts except the rear main seal close to home (southern ohio). what"s the story on those seals sorta an odd set up looks like it had a felt washer on it at one time am I missing something ? Thanks in advance old dude.
jerry herger
03-16-2005 15:49:27
 Re: 550 bottom end in reply to old dude, 03-14-2005 05:36:22
Doing research on 1958 550's. does yours have regular rear rims(non power adjust) amd are they red or white. Mine is original and they are red. It is an early 550 serial 64069 and I am trying to find out at what serial Oliver started painting the rear rims white. Thanks.
StumpZ
03-17-2005 05:43:58
 Re: 550 bottom end in reply to jerry herger, 03-16-2005 15:49:27
Jerry, I have a '58 with the serial 61-142. My rims are white but I haven't looked at them closely to see if they have red underneath. I'll take a look this weekend. They are the larger size option though.
old dude
03-16-2005 19:02:57
s/n 67 716 519 red rims not power adjust type
Jim Kline
03-14-2005 16:05:03
Call Faris Imp. in New Vienna, Ohio. 937-987-2112 Talk to Roger. He has what you need on the shelf.
old dude
03-14-2005 17:18:03
 Re: 550 bottom end in reply to Jim Kline, 03-14-2005 16:05:03
thanks, Jim all ready made an order to the Korves boys.Got another question for you. Do you live around greenfield ohio area? If so you may have known my dad -cork morris- st. rt. 138. frankfort. found your name and alot of oliver part numbers on scraps of paper in the barn and the top of one of his tool chests. 550 -1550- 1850-
Jim Kline
03-15-2005 14:59:31
 Re: 550 bottom end in reply to old dude, 03-14-2005 17:18:03
That would be me. Just live up the road towards Greenfield from your Dad's place.
