Sort of OT Galion road grader
old
03-10-2005 15:02:26
First off any body know where to find parts for a 303 grader. Now heres how it gets to the oliver part. This thing has an IH engine and on the tranny it has an Oliver corp tag. I think it doesn't know what it wants to be a galion or IH or oliver. Oh well as long as its part Oliver and can live with it, I think I have it brought at least I hope I do.
J. Schwiebert
03-10-2005 15:43:36
 Re: Sort of OT Galion road grader in reply to old, 03-10-2005 15:02:26
Rich:I seen that post on the other site.It is an older grader. It has an Oliver engine over axle transmission. Oliver made them in two distinct sizes. What model IH engine do you have? Then maybe I can start to figgure out what model transmission/final drive you have.
old
03-10-2005 15:52:18
 Re: Sort of OT Galion road grader in reply to J. Schwiebert, 03-10-2005 15:43:36
Not sure about much right now, I looked at it today and noticed an IH on the side of the engine, its a 6 cylinder and on the tranny the Oliver tag. Its a galion 303 6 wheel with 4 pulling tires on the rear. I need to find a part for the steering, its the part that goes in to the worm gear on in the steering box, looks like it would be a set of bearings holding eithe a set of teeth or holding a teeth bar but since its missing I'm not sure. Thanks
J. Schwiebert
03-10-2005 17:39:31
 Re: Sort of OT Galion road grader in reply to old, 03-10-2005 15:52:18
We used to have a customer along with farming did some surface drainage work. He had 4 Galion graders with IH engines. They were all diesels. I have also seen them with a J & C Cummins. Also some had an Oliver four cylinder engine.
old
03-10-2005 18:11:14
 Re: Sort of OT Galion road grader in reply to J. Schwiebert, 03-10-2005 17:39:31
From what a guy up in the crawler area in this forum area has told me it has a 560 IH engine in it. Also think I have found the parts, now I have to see what type of deal I and do with the dealer that has it. I hope I can get him to pay for the parts and let me do the work since labor now days is always more then the parts. But with this guy you never know. I do know it sure would make it easyer to work on my drive way with the Galion over my WC allis speed patrol.
Wrenchbender
03-10-2005 19:24:18
 Re: Sort of OT Galion road grader in reply to old, 03-10-2005 18:11:14
If it is a 560 engine the cu in will be stamped on the block along with a ser #. It will be located near the oil filter base on a flat spot that's on a horizontal rib on the block. It should be a C 221 or 263 if it's a gas and a D 2XX if it's a diesel. I think I'm right about the cu in, WB.
J. Schwiebert
03-10-2005 18:54:16
Check it out thoroughly. The 4 graders the guy I knew had all started on gas and switched over. If it looks like a 560 check close. They made three different size engines out of those blocks. Take a look at that Oliver tag and see if it is for a model 50 or the later model 500. I doubt if it is for the smaller one. Good Luck.
