Oliver 77 gaskets
RKM
03-08-2005 04:08:36
Some parts suppliers list the same head gasket set for a 77 gas and diesel. Others show two different sets. Could someone please tell me if they are the same.
Jerry from East Iowa
03-08-2005 10:24:55
 Re: Oliver 77 gaskets in reply to RKM, 03-08-2005 04:08:36
Hi I sell head gasket sets, let me know if you are interested.Most of the kits that I have run into that say same kit for both, have both head gaskets in them. Hope this helps.
[email protected]
Thanks
:) Jerry
Jerry's Tractor Repair
Holy Cross, Iowa
563-552-1615 or 563-590-1973
P.S. I very much doubt that you will be able to match a head gasket# with anything made now.(even if you can read it)Your best bet is to measure your bore and compare it to original.
J. Schwiebert
03-08-2005 04:25:48
Oliver had a seperate head gasket for each. Another thing, It is going to make a difference if your 77 has the standard bore or some oversize bore. Get the wrong one and you can either crack a sleeve or damage the gasket. Why not take the number off the old gasket and match it up? Questions
