PTO questions
DaveKS
03-06-2005 20:01:56
Bought a 550D couple yrs ago that the PTO seemed to engage and disengage OK but now does not disengage at all. I may have overfilled the transmission at some time ago. Would this cause the PTO clutch to slip? Also, believe it or not, I opened up the PTO clutch adjustment cover and found a chrome nut setting on the top side of the cover plate. As you can imagine, I'm wonderin where the heck did that come from? Pretty good size - maybe 1/2 inch at least.
Nut aside, I've checked some past PTO slipping probs on this site and it appears I may be in for some major work. I've also adjusted the PTO clutch like it says in the manual to no avail. Suggestions? At this time, I don't have the free time or expertise to get into an overhaul without help but maybe a few years down the road when my honey-do list is cut down a bit.
