Power Booster Removal on Oliver 770
Jeff Craig
03-06-2005 16:09:16
I need to remove the power booster to repair a oil leak. I have a IT manuel but it doesnt seem to make since or work. I have the engine out but I cannot get the bell housing or power booster out.
cobroller
03-06-2005 18:57:44
 Re: Power Booster Removal on Oliver 770 in reply to Jeff Craig, 03-06-2005 16:09:16
Did you remove the long pto shaft? Remove the six bolts holding the power booster clutch together--save each shim pack separatly. The bell housing and front half of the power clutch should have came out with the engine.
Jeff Craig
03-06-2005 19:52:39
 Re: Power Booster Removal on Oliver 770 in reply to cobroller, 03-06-2005 18:57:44
I did remove the engine but not the bellhousing.I can"t get the pto shaft to come outso i can remove the powerbooster. Is there a snap ring or something I am not seeing. When I try to pull the shaft it will move about 1/8-1/4 of an inch and then it stops very solid.
cobroller
03-06-2005 20:55:13
 Re: Power Booster Removal on Oliver 770 in reply to Jeff Craig, 03-06-2005 19:52:39
It comes out the rear of the tractor after you take the cover off the pto clutch. Remove the three 3/8s bolts in the bearing retainer in front of the clutch pack and the shaft and clutch come out together. If you bent the pto drive shaft while pulling the engine it may be hard to get it out.
Jeff Craig
03-07-2005 05:30:28
 Re: Power Booster Removal on Oliver 770 in reply to cobroller, 03-06-2005 20:55:13
Hey thanks for your help. I don't think I bent the shaft but it was tricky getting the engine out due to it had flanges behind the motor mounts and I had to lift the engine a good 1 1/2 inches to clear the mounts. I will look for the retainer bolts but it seems like the shaft goes from the bell housing through the power booster clutch and into the power booster housing. I don't remember seeing a bearing retainer. I did remove the clutch cover bolts and cool fins.
Kent of SW MO
03-08-2005 06:28:32
 Re: Power Booster Removal on Oliver 770 in reply to Jeff Craig, 03-07-2005 05:30:28
The shaft is removed from the very rear of the tractor, NOT the rear of the power booster. Remove the cover above the PTO shaft and remove the three bolts that are in front of the PTO clutch. Sounds like you need to invest in a SHOP MANUEL.
Kent
