More plow questions
drsludge
03-06-2005 14:00:44
Has anyone seen or know where a model number 475 oliver plow could be bought.this plow came out about 1966 with the automatic-reset cylinders on the bottoms(like the 575 3-point)and is a pull(trailer)plow.Also what about the late White plows I would of thought that a pull plow would of been made(thinking 549 or 508 or 588).speaking of plows Oliver made the Case plows in the 70s to Case specs,also the D.M.I. plows used Oliver bottoms.
IanC
03-06-2005 20:28:34
 Re: More plow questions in reply to drsludge, 03-06-2005 14:00:44
There were trailer versions of the 548 and 549 semi-mounts. 448, 449 respectivly. Not very common here in MI, but maybe elsewhere. There were also 450 trailer plows that were the same backbone/frame as the 475/575, but with cushion trip or shear bolt instead of hydraulic reset.
drsludge
03-06-2005 20:43:12
 Re: More plow questions in reply to IanC, 03-06-2005 20:28:34
I am in Wi not very common here.Just bought a 450 a while back and I already own a 4340 and three different 4440 (4,5,and 6 bottom)plus a few old model 100s.I like pull plows and would like to add a few more.Only bad thing is the only 450 plow I have ever seen is the one i just obtained.
