george md
RickB
03-05-2005 10:57:59
George, a while back you and John were giving me a lesson on cylinder heads. You looked up the head thickness for my Oliver 660 and I have 4.5" written down as the spec for a new head. My head measures 4.061" from the rocker cover gasket rail to the head gasket surface. Wondering if I wrote the number wrong as I took it off your posting. Casting numbers 180602 and 102379A. Any help you can give is appreciated. Rick
george md
03-05-2005 21:07:33
 Re: george md in reply to RickB, 03-05-2005 10:57:59
Rick,
Either my book is wrong or some one has really been cutting on your head.
Both numbers are listed for 155 & 176
engines with 4.5 as new and 4.470 as minimum .
I will look and see if the waukesha books say
anything else.
george
RickB
03-06-2005 03:20:07
 Re: george md in reply to george md, 03-05-2005 21:07:33
Thanks, George. The tractor is fairly original, but of course the engine has been apart over the years. I cc'd the head @ 91cc's which yielded a very stock compression ratio. Also the transition area between the head surface and chamber in the area away from the cylinder wall has no sharp edge as if it were machined without having that edge dressed. Does look to be a little thin at the water passages though I have no basis for comparison. I would like to have hard info before shaving it. TIA, Rick.
george md
03-06-2005 10:46:50
 Re: george md in reply to RickB, 03-06-2005 03:20:07
Rick,
I looked in the wauk books , they are all
parts , kits ,price, and build sheets but no
dimensions.
george
RickB
03-06-2005 11:34:17
 Re: george md in reply to george md, 03-06-2005 10:46:50
Well thanks for looking.
