88 ring and pinion
akiefer
03-01-2005 21:29:02
I have a 12 tooth pinion shaft #K608C and I am looking for a ring gear. Can anyone tell me what part # ring gear will fit this? I know that the #K644B is a 47 tooth that matches a 10 tooth pinion but I can"t find any info for the 12 tooth. thank you
Marty S
03-01-2005 22:17:30
 Re: 88 ring and pinion in reply to akiefer, 03-01-2005 21:29:02
Not trying to be a stickler, but would your pinion and shaft not carry part #K-602-C rather than K-608-C? Working off the assumption that it is pinion and shaft # K-602-C, you would be looking for ring gear part # K-644-C. This is the match set for an Oliver 88 with a 12x47 ring and pinion set up. You are correct in you statement that the match ring gear for pinion K-602-B is K-644-B. This is a 10x47 ring and pinion set up. 88's also came with 9x51's (slowest found in RC's),11x48's (found in RC's) and 13x48's (fastest, found in a few standards and a few industrials). I have a 47 tooth ring gear still in rearend. As you probably know, a ring and pinion gear should like a pair of Canada geese, mate for life, so as to keep wear identical. You can contact me at (316)722-4270 if you are interested in the 12x47 ring and pinion set or just a ring gear. Matters not to me. Hope this helps more than it confuses. Evenings are best. 7-10 CST.
