Starter interchange for Oliver HG 42?
Packard8
02-28-2005 08:05:28
The starter on my HG 42 (12V) just quit. Is this starter interchangeable with other automotive/tractor applications? I�m hoping to get a reman exchange, but I expect to get blank stares if I go to Autozone and ask for a 1948 Cletrac starter.
Thanks
J. Schwiebert
02-28-2005 09:22:54
 Re: Starter interchange for Oliver HG 42? in reply to Packard8, 02-28-2005 08:05:28
That should be an Auto-Lite starter. Some OC-3 tractors also used a Delco which will interchange. None were 12 volt.
Packard8
02-28-2005 10:08:22
 Re: Starter interchange for Oliver HG 42? in reply to J. Schwiebert, 02-28-2005 09:22:54
I just bought the tractor a week ago and don�t know its history, but it has a 12V battery (for the starter only, no generator or alternator installed). The old starter is a Delco Remy model 1109602 6C27, but with no voltage marked on the case or tag. My experience with old cars is that often the same starter was used by several makes & models and was hoping someone on this list might know of an interchange. I�m hoping to find an exchange unit locally, otherwise I�ll have to send it out for a rebuild.
Thanks
Ray Z.
02-28-2005 12:21:17
 Re: Starter interchange for Oliver HG 42? in reply to Packard8, 02-28-2005 10:08:22
That starter was normally 6 volt, but a lot of times people put 12 volt to it to make it spin faster.
Unfortunatly that starter was not used in any autmobile applications, if you have a starter I would advise on getting it rebuilt. If you need a source, give me a call.
Packard8
02-28-2005 14:35:52
 Re: Starter interchange for Oliver HG 42? in reply to Ray Z., 02-28-2005 12:21:17
Thanks Ray,
I took the starter to a local auto electric shop and they will go thru it. BTW, do you know what the factory curb weight is for an HG 42?
Best,
John
champspa
02-28-2005 15:24:45
 Re: Starter interchange for Oliver HG 42? in reply to Packard8, 02-28-2005 14:35:52
the weight on mine is 3900
Ray Z.
03-01-2005 03:59:21
 Re: Starter interchange for Oliver HG 42? in reply to champspa, 02-28-2005 15:24:45
The HG-42 weighs 3500 lbs. bare crawler no attatchments
Packard8
03-01-2005 05:59:59
 Re: Starter interchange for Oliver HG 42? in reply to Ray Z., 03-01-2005 03:59:21
Thanks Ray & Champspa
