Oliver 80 Governor Question
Kirk in PA
02-27-2005 16:38:27
I'm rebuilding a Waukesha VIK21F governor. Upon disassembly, a single ball bearing came out and I did not see from where. This ball measures 0.4375 inch. There are no balls missing from either of the bearings and they are too small anyhow. The only place that I can imagine it coming from is the bottom of the blind hole for the shaft of the fork lever that pushes against the weights. Can anyone enlighten me?
Thanks,
Kirk
RAB
02-27-2005 22:58:52
 Re: Oliver 80 Governor Question in reply to Kirk in PA, 02-27-2005 16:38:27
Correct, but I think you will find it should be 0.375 inch, but can"t be sure unless I dig out the parts book.
Regards, RAB
Kirk in PA
02-28-2005 04:26:33
 Re: Oliver 80 Governor Question in reply to RAB, 02-27-2005 22:58:52
Thank you for the response. You are right on the size. Some fuzzy memory on my measuring. Thanks a lot.
