Super 55 fuel system help
John Wilson
08-11-1999 05:02:38
I've committed the cardinal sin- I let my 1955
Super 55 run out of gas while bush hogging. I added 4 gallons and restarted after about a 10
minute cool-down. I had to use the choke briefly
and it ran good for about a minute. Then it started to run a little rough at high speed and
at half throttle. Anything slower and the governor
causes it to speed up and slow down. Forget about
idling at all.
What can I do to get back to normal? It did run
fine before this incident. I really don't want to
pull either the governor or carb! I haven't tried
anything yet until I get some feedback from some
of you experts. Am I screwed?
Thanks for any and all replys. I'm kind of new to
this vintage tractor stuff.
Also, where is a good online or mail-order parts
source for Oliver parts, used, new or after-market
it doesn't matter.
John
Bob M
08-12-1999 12:35:56
 Re: Super 55 fuel system help in reply to John Wilson, 08-11-1999 05:02:38
Same thing happened to my 1600 several years ago. Problem was apparently a slug of water and dirt/rust got thru the sediment bowl as the gas ran out which plugged an orifice inside the carb. A couple things to try:
1 - Remove the drain plug from the carb bowl and let the stuff in there run out. Then open the gas shutoff and let a cup or so of fresh fuel flush through. If nothing comes out when you unscrew the plug, GENTLY poke up in the opening with a popsicle stick or something to open it up. 2 - Tighten both mixture screws until they bottom out, while carefully noting how many turns each screw req'd to bottom. DON'T seat 'em right tight - just tighten until they are snug. Then remove both screws completely. Now take an air gun and shoot a blast of compressed air into each screw hole, being careful not to blow any dirt into the openings. Finally replace both screws, adjust them back where they were before and reinstall the drain plug. If you are lucky your problem will be solved. If not...
3 - You'll need to open the carb and give it a good cleaning. It's not very complicated - just lay the parts out in order as you remove them, then replace in reverse order. Good idea to have a new carb gasket kit on hand before you begin.
Good luck!
