Help with Side Sheild
JeffK-MN
02-17-2005 12:41:35
I have a 1950 Oliver Row Crop that is a great tractor for my uses. It is in very good shape but the guy how had it before me changed it to 12 volt and now you can not close the right side sheild it hits on the altenater. sorry for the spelling What have some of you done to fix this? Or will I have to change it back to 6 volt Thanks Jeff
Geoffrey in KS
02-18-2005 13:07:19
 Re: Help with Side Sheild in reply to JeffK-MN, 02-17-2005 12:41:35
I prefer converting the 6-volt generators to 12-volts. It does not cost much more than rebuilding it as 6-volt, it looks original and if the battery runs down you can jump start the tractor and go. With and alternator, you can damage the alternator if you make it charge a dead battery. My 2 cents.
Wes Dorhout
02-18-2005 07:33:44
If you take your gen. mounting bracket off the front cover and turn the alt. upside down and drill out the 5/16 bolt treads that were used for belt tighting and then mount the alt. with a 5/16 bolt on the front cover and a longer 5/16 bolt on top. you will have to shim it out on the bottom and alter the top bracket a little. You will have to use a shorter belt and put the alt. as tight as possible against the engine.
Steve Metcalfe
02-18-2005 06:25:09
I have changed all of my fleetlines over to 12 volts by taking the generator to a rebuilder and having convert over from 6 volts to 12 volts. That way the side curtain will close properly and it will still have that original look to the engine.
anothertractor
02-18-2005 05:01:30
Hey Jeff,
I bought a one wire alternator for my 77 and the side curtain wouldn't close. I took it back to the alterantor shop where I bought it and the guy told me to come back in a few days and he would have something for me. He took an alternator from a Mitsubishi car and rebuilt it. It worked perfectly. It was only about 4" in diameter. Good luck.
Keith
Texas Denny
02-17-2005 16:06:45
I have an alternator on my 77 gas and I can close the side shield. I did have to put a guard on the alternator to keep the alternator fan from touching the side shield. Maybe a shorter belt would help you or a smaller alternator or as Jeff suggest a 12 volt generator.
BrianC
02-17-2005 13:25:13
I believe if you use a 12 Volt generator from a diesel 77, you'll have enough clearance to close the side shield..
1755
02-22-2005 17:44:43
 Re: Help with Side Sheild in reply to BrianC, 02-17-2005 13:25:13
Would one off a 66 work with the squar box sticking out threw the curtan
1755
02-22-2005 17:44:19
