Oliver 88 Wide Front
dennis white
02-14-2005 04:41:23
to change an oliver single front to a wide front end do you need the entire belly pan? thanks in advance.
old
02-14-2005 18:01:28
 Re: Oliver 88 Wide Front in reply to dennis white, 02-14-2005 04:41:23
Not to bad a job to do if you have 2 or 3 people to help. I know I sure would do it by my self it can be hard to gett every thing to line up alone
SPT
02-14-2005 05:02:15
You need gear box, and wide front axle, belly pan does no have to be changed. Disconnect steering rod to gear box, remove bolts from narrow front, drop out of the way, bolt up wide front gear box, attach steering rod, slide wide front on pivot point, braces that extend rearward have a plate that bolts under belly pan.
Pretty easy job if you have all the parts, jacks and engine lift to help move wide front. Take your time and be careful.
The extra one I have weighs a ton, all cast and very heavy.
