OC-3 Engine
Greg
08-09-1999 03:44:05
Can anyone suggest where to find complete Hercules
engine for a oc-3. Actually need two as have a Cletrac General in same condition. Thanks
Dan Maloughney - Condon, Montana 59826
03-20-2001 18:00:10
 Re: OC-3 Engine in reply to Greg, 08-09-1999 03:44:05
I am rebuilding my OC-3. The part I am most concerned about is the crank pulley. I may have to build up the crank, and therfore would like to have a pulley in good condition. The bore on mine is shot. Any suggestions?
Charles Stangeland
08-28-1999 11:22:39
Just got an 0-C3 running. I thought the motor was a total loss. I found this oc-3 in a costal norther CA town. It had the exaust open to the rain for 30 years. I beat the pistons out with 12lb sledge and a peice of wood. Replaced the rings honed the cylenders clean and ground and laped the valves. Runs real good! What I'm saying is that this is a very rugged motor that is very easy to rebuild. But Landis has any thing u need. Need any advise let me know.
Charles
mm SURPLUS
07-07-2000 20:58:10
 Re: Re: OC-3 Engine in reply to Charles Stangeland, 08-28-1999 11:22:39
CALL 17188289026 FOR PARTS
martin mueller Oshawa Ontario Canada
08-15-1999 10:34:04
Hi there. I can,t help with an engine but I have an OC-3 also. I would like to make it operational.It seems complete less the motor.
Would you be able to suggest where and how to get
started on repairs?? manuals? web sites?? parts? specs.?? etc.... This is my first attempt to repair /rebuild a tractor..
THANKS
08-15-1999 10:33:52
THANKS
08-15-1999 10:33:40
THANKS
John in Pa.
08-10-1999 04:33:56
Greg, have you tried Landis Zimmerman at 717-738-2573 ?
